Hi Steve,
I beg to differ a bit on your analysis of the E90.
1) Series 80 being tied very much to Symbian OS 7.0.
I don't think this is true. A Symbian OS user interface has very little to do with it's inner workings. Because of the modular design of Symbian OS, it is possible to have number of different UI's on the Symbian OS, witness UIQ 3.x and S60 3rd ed on Symbian OS 9.1, and UIQ 2.x, S60 2nd/1st and S80 on earlier versions of the OS. I don't see any technical reasons not to have Series 80 on Symbian OS 9.1.
2) The hotkeys and the menu.
Hotkeys are necessary for power users, and power users are the ones using the E90. Witness the number of S60 apps having shortcuts, even the builtin ones.
True, on Psion there were so many hotkeys that you couldn't learn them all, and true, not all apps were using the same ones for the same task.
However, Psion made it very clear which shortcut was for which action. Professional developers generally followed this guideline. Nokia did exactly the same for Series 80, BTW.
Now with S60 hotkeys not being standardized at all, you get a much bigger mesh. Without guidelines or consistent examples from Nokia, everybody is just messing around. '*' is zoom in in the webbrowser, '5' is zoom in in Galleries. '*' is full screen in Galleries '2' is full screen in Real Player.
Had Nokia standardised on shortcuts, they could easily used Symbian Signed, or their own approval program, for enforcing the shortcuts, eliminating more confusion.
Not all apps show the hotkeys in their menus, and those who do so all use a different method (before the command name, after the command name, between (), between []). This is ugly and it looks unprofessional. This is a 700 euro device and what do you get? You get ascii art 😉
That the menu structure works very well for the E90 in closed mode isn't the point. You buy an E90 because you can open the clamsheel and have a querty keyboard and a big screen.
3) Faxing. If the lack of faxing is a dealbreaker for many potential E90 customers, I'd certainly be worried if I were Nokia. The people that complain in these fora are likely to need faxing on a regular basis, that's why they complain about the lack of it.
Sander van der Wal
mBrain Software
