Automatically change profiles at set time
9 replies · 10,270 views · Started 06 July 2007
Hi all
Got my new N95 and very happy with it. However I was wondering if anybody knew if there was any third party software (I presume the phone cant do it natively) that allows you to change the phone profile at a set time.
For example as I go into a daily meeting at the same time each day I would like it to automatically change to silent/meeting profile at that time. Or it could be set to go into offline profile overnight to save on battery power.
It would seem such a useful feature that I was hoping phone had it included but I can't find any thing.
Can anybody help?
Thanks in advance.
Hi Hounddog
Thanks for the quick reply. Yes this looks just what I was looking for! 😊
One quick question.
Does it need to be constantly running iin the background in order to change the profiles and if so, does it cause a noticible drain on the battery?
amcneil wrote:Hi Hounddog
One quick question.
I use BestProfiles too, I have not noticed any significant drain on the battery
Once activated it runs hidden in the background and auto starts when rebooting the phone and its RAM usage is tiny.
One of the best apps available.
It is really good and I haven't noticed any extra drain on the battery either. It's easy to turn the program off as well, for holidays etc.
It may be of interest for some of you: the new version of Autoprofiles has been released, enhanced with Bluetooth scheduler and some other features.
Your comments are welcome!
SymbianGuru
Hello,
Now the software AutoProfiles is fully compatible with the latest mobile phone Series 60.5: Nokia 5800 XpressMusic, Nokia N97
You are welcome to try for free the AutoProfiles application as well as download pdf user manual on www.symbianguru.com
All the best
