Updated Firmware with Map Issue!!
6 replies · 2,370 views · Started 07 July 2007
Hi everyone,
I jus updated my firmware and found everything to b more than perfect. Here's the prob; the first time i used Smart2Go it was smooth n all but wen i exit the program the run it the second time it froze. But the third time it was gd, the fourth time froze, fifth was fine n so on. What the hell is up can someone help ?!
and some questions here:
What is the internet connection for ?! like for Smart2Go?? (sorry i mite b stupid here but i reli cnat figure it out)
I downloaded the new Maploader but i duno if the maps are new?! cuz i see no difference.. how can i check?!
Thanks yall!
monica _69 wrote:i beg to differ, check out the thread now, seems they have it all sorted now, works fine
Yeah, people were all trying to install the update to the memory card for some reason... silly...
Just install it to the phone memory and you are fine.
Do note that this update is only a pre-release version though, it's not THE next version of Maps. It was on smart2go's website for a few days before disappearing again, so there may be issues that we aren't aware of. Tracking has been removed in this pre-release update, but as far as I know it WILL be back in the proper update.
Tracking ok here with this update. i just press 0 or whatever is key to "where i am" and program move maps
according to my move.
