is there a way to disable the screen saver ?
and how can one lock the keypad without closing the slide ?
[quote="jaffa_cree"]is there a way to disable the screen saver ?
and how can one lock the keypad without closing the slide ?[/quote]
Press the power off button (red button,on the left side of the phone)
then move the joystick up and press lock keypad.
About the screensaver,i dont think you can,at least without a third party app.
Try leaving an app runing 😃
There goes the battery 😃
[quote="GhostDog"][quote="jaffa_cree"]is there a way to disable the screen saver ?
There goes the battery 😃[/quote]
cheers
thanks for that
it really annoyed me that i had to keep on opening the slide just to keylock
RTFM
Now, now MemphisX, be friendly to people 😉
[quote="Merlin"]Now, now MemphisX, be friendly to people[/quote]
Why?? That is my favourite answer to a question.
I shall remember that when you ask ask a technical question! :P
I definitely agree,AAS is a friendly community,if you are not in the mood the answer newbie questions,dont answer them.
You can direct them to use the search function,or even politely ask them to.
Thank you.
