Zayshan wrote:I put the memory card in to a reader then on my computer I accessed the memory card and created a folder called �my music� if you already don�t have one. Then I copied all my music albums from my pc and pasted it in to the memory card folder named �my music�. Put the memory card back in to the N95 and went to the �Music Player� Once in there press your Options button then select Refresh Music Library. The N95 will search for all the music you have on phone and card, showing you at the end how many music files were updated. Then select Albums and all your music folders should be in there! I don�t use any 3rd party music player or software just copy and paste, hope that helps.PS. The reason I'm using a card reader is because it tranfers the music much faster than actualy hooking up the N95 to the pc.
Unfortunately that doesn't work very well for me.
I'm talking about creating my own folders (with my own folder name).
For instance, I have a collection of miscellaneous music tracks (might be a mix of Rock, Pop, Jazz, Funk, etc. etc.). So I create a folder called 'Misc' and dump all these mixed tracks in it.
What I expect to happen is that I drag this folder to 'My Music' on the memory card, pop the card in the phone, refresh the library, then navigate to 'Albums' in the Music Player and select the 'Misc' Album/Folder and start playing the tracks.
What actually happens is that there is no 'Misc' Album/Folder to select, instead the 'Albums' function shows each individual album that these miscellaneous tracks are from (along with all the actual separate albums I have)
If I go to 'All Songs' of course, I get all the MP3 tracks listed alphabetically including those from inside each individual album/folder (plus some Audio Books I have) in one long list. Obivously I don't want to play this All Songs list as it will jump from music to audio book etc, as well a splitting album tracks (ie. Beatles - Love) up alphabetically.
It's OK if with my actual standard album folders (ripped from standard CD album), but with a collection of tracks from different albums, it's unusable.
It's pretty simple, all I want to do is navigate to a folder and start playing what's in it. I have a �30 4GB Sansa MP3 Player that understands this, whereas a �400 flagship phone doen't seem to.
Am I still not getting it?
*sorry for the long post*
