Is Tom Tom 6.030 compatible with N95?
9 replies · 5,806 views · Started 30 July 2007
monica _69 wrote:yes, you are correct ! both 6.010 and 6.020 :icon14:
let me know if you need help, pm me
Is there any difference between both versions, apart from handling one more type of phone?
slawmilcz wrote:Is there any difference between both versions, apart from handling one more type of phone?
I'm not sure what the difference is to be honest, I used to run 6.010 and it was fine, then changed to 6.020 and it also runs fine, haven't noticed any difference though.
I only changed to 6.020 as it's a higher version number.
As I know, the only difference is that ver. 6.020 handles one more type of phone. I don't remember which one, as I read about it some time ago.
