The Collection of E90 bugs and missing features
6 replies · 4,328 views · Started 04 August 2007
Newer models have wider space? Is this true? If it is, what date is this product manufactured or what product code does it have? Where can i see this information?
@Klarsen
1. My E90 never takes more than 2 minutes to get a gps lock, usually 1.5 minutes
2. My Nokia BH-500 A2DP is perfect unlike the HBH-DS970, therefore probably a SE issue
bassist_x - i have not seen it with my own eyes. so I have not visually confirmed it. But the pads in the corners of my phone does hardly touch the "base plate...". I think it needs bigger rubber pads.
jah - headset - MY 970 works fine for calls and music - it is just when my phone beeps when pressing a button or the like - then the sound is kind of cut initially. Playing music etc. works fine. But since Ericsson is the founder of Bluetooth ... do you still think it is not a Nokia bug?.... 😊 (of course it might be a SE bug...)
GPS - hmm maybe it is geographic dependent. I think my shortest time has been 4 minutes. Where are you located?
btw - just updated the list with a new bug - the phone does not allways register keyboard correct. (open/close condition)
http://kaz911.blogspot.com
@klarsen
It has been confirmed by many posters of problems they have using the DS-970'S even with SE devices, besides which they BH-500's allow you to plug in your own headphones and have better battery life and quality a much louder better defined sound.
Marc
thanks,
i spoke to a service center and they claim to be able to update the firmware in the 970 headset. But they charge for it. So i might try another. But the BH-500 is only Bluetooth spec 1.2 not 2.0.
@klarsen
I am just not a fan of Bluetooth headsets for listening to Music and much prefer a wired solution, just wish Nokia had used a 3.5m plug instead. I have no issues with the screen touching the Keyboard or the rubber feet not being even either.
I also have no intention of using the built in GPS as prefer to run Tom Tom with my Holox BT-321 receiver as believe this offers a superior experience.
Besides that and although i have only had my E90 a few days it is the first commie i have used, i have only converted to S60 for a little over a Year ago now and as far as i am concerned it just keeps on getting better. So far the only bug i have experienced was i had to manually input my voice mail number for the 1 key but that's it, just hope it stays that way.
Marc
