Copilot 6 live?
4 replies · 2,705 views · Started 09 August 2007
Erhm, should anyone have a working link to Copilot live 6 (the one working on n95) i would really like to testdrive the bugger before bying it 🙄
My expirence - Nokia maps, gotten better in its routeplanning, since new mapupdates but still failes in 1-2 out of 5 routes, (gets me there buy buy far not the fastest etc.)
Route 66 - same 0, and graphics is far worse and undetailed, it could live with that if it vere PRECISE in its calculating, but its not :icon13:
Viewfinder, dosent make map for my region (DK) soo it cant try it :redface:
Navigon V.6.3 !!! I simply havent got the money :frown:
Tomtom isent ready :icon4:
guess there is no software back then !!!
So bottom line is - with my new N95 i dont even have a reliable GPS for my car :con? arrgh
Greets all :tongue:
If you cant afford navigon, you cant afford copilot because they are both the same price.
While I fully appriciate you wanting to testdrive copilot (exactly what I wanted to do) I really dont advocate pirate software.
I guess the cheapest way getting an relaiable GPS system then (Whitout bying more crappy half finised/working software) is to buy an external GPS and use the 'arrgh' tomtom :redface:
I've already paid nokia 1 year subscription, and dident think, at all i woudent work perfect. 😡
Anyone now a good working external GPS to use with N95 :con?
Greets all 😊
hansihansi wrote:I guess the cheapest way getting an relaiable GPS system then (Whitout bying more crappy half finised/working software) is to buy an external GPS and use the Astoundingly Amazing version of tomtom :redface:
Greets all 😊
Aye Tomtom is the best by far, in regards to the external GPS I use a Holux external mini gps reciever and it worked on my N80 and my n95 perfectly. Takes a while to get connection sometimes 5 - 10 minutes depending on where you are and takes longer if the last time you had it on was quite a distance away.
