How can I remove or disable the WLAN icon from appearing constantly in the main screen during the Active Standby mode?? I dont mind all the 5 shortcuts under the navi pane and the calender icon, but can I get rid of that WLAN scanning icon somehow??
Device -- Nokia N95
WLAN Scanning icon.. How to remove??
Dont think you can, The only way to remove it is to turn active standby off, but it also turns off the calender icon and the 5 shortcuts.
Ive seen screenshots with Active Standy enabled, without the WLAN scanning icon..
