7650 experts
8 replies · 2,505 views · Started 16 January 2003
hi peeps, need your help badly, i have a big problem wid my 7650 in
my sms outbox there is one msg that i cant delete or do anything
with it. now my phone has an outbox icon im irritated with dat. pls
help me. if i use handyfile can i locate the outbox msg and delete it
manualy. and where is the specifc location of the outbox
it is not necessairy to remove with handy-file.
U even would only crash your message-option with it.
try this:
remove the Sim with another.(if u got no other,�sk one of a friend.)
then u can delete the sms.
If it not work,put back the old one,try now to delete the sms,
and at least it shout be fixed.
S�mi
If nothing seems to work (for any reason :cry: ) and you can't bear that message stuck in there, throw it on the wall!! :P
--just writing this in case NOTHING seems to work, never had this message problem before, but writing this so people could fix alotta problems! (been discussed alot before, here's the important tips and procedure) --
well actually, you can format it, but make sure you sync all your contacts, and back up your files and pics and stuff, cause you're realling "formatting" it. You can find alot if you search, but here's the headlines:
Be sure to sync your contacts and send your pics and stuff to a computer
Be sure your battery is full
Plug in the charger switch for safety
The code is: *#7370#
[quote="😊"]If nothing seems to work (for any reason :cry: ) and you can't bear that message stuck in there, throw it on the wall!! :P
quote]
No, no! Throwing it at the wall is only for when you can't finish a level of Vexed on the 9210.
[quote="Rafe"][quote="😊"]If nothing seems to work (for any reason :cry: ) and you can't bear that message stuck in there, throw it on the wall!! :P
quote]
No, no! Throwing it at the wall is only for when you can't finish a level of Vexed on the 9210.[/quote]
😃 😃 😃 smiley and his crazy ideas! 8)
I have same problem, probably it is bug of firmware. Excuse me my English, I am from Czech Republic
quote]
don't do that, let me try to clear that level for you, pls send the phone to me, I will try my best to clear it,then I'll return u the phone(not until i cleared that level)
Hope someone has an idea to remove it without affecting other messages. it really sucks....
quote]
LOL!! 😃
well cleo8888, that might just work!! 😃
