z8 + divx
2 replies · 5,915 views · Started 15 August 2007
I want to install divx player mobile on my z8.
It has loaded ok but when i go to run it, it says ''program closed.''
Anyone know whats wrong?
How do we get other movies on the z8?
Thanks. 😉
There are plenty of app out there that will convert to the right format for Z8. Clone DVD mobile is good, Apple Quicktime pro is good etc. I also like the free youtube to ipod convertor by dvdvideosoft
Make sure you convert to 320x240 or you wont get full screen. Try to get the audio to 44Khz 128Kbps and the video i would recommend is either h264 at approx 384Kbps or Mpeg4 at 512Kbps.
Apple's program is good, and pretty cheap. Z8 supports virtually the same as an Ipod video.... so check out programs already out there to convert for ipod.
