battery covers
7 replies · 3,546 views · Started 17 August 2007
hihi,
LOVE my E90 so far - feels sooooooooo solid compared to the N95....
but I notice the battery cover is a *tiny* bit loose - normally would not care but the rest is so well built I noticed it!
is this the case for other people? I wonder also, can you buy a replacement cover from anywhere?
jah wrote:Replacement cover from www.l8shop.net - they also sell the complete E90 housing as well!
thanks for the link - seems they are out of stock alas...
Its really starting to annoy me - the phone is so solid elsewhere, but when I am typing I can feel a slight movement in the battery cover which is not massive but so irritating! Any ideas how to (elegantly) fix this?
Or is anyone else selling replacement covers? I see mobilefun.co.uk do but they are out too... and I am not sure I trust ebay to get a genuine item....
yes, same as mine...
I put piece of paper, on the top of battery,
on right side of connectors. Now everything is ok.
But, I am little dissapointed because so expensive phone
with so "china" parts...
regards
gervasius wrote:yes, same as mine...
regards
yeah totally agree. its strange how the rest of it is so well built and the battery cover seems to be an after-thought. I ordered another cover from:
http://www.telecomtelecom.eu/index.php?p=5&id=8561
if its also crap then I will try the paper idea - or blu-tak 😊
The battery cover on my Made in Finland E90 does not move at all. There is however some slight "squeaking" at the top where the speaker is.
Arthur wrote:The battery cover on my Made in Finland E90 does not move at all. There is however some slight "squeaking" at the top where the speaker is.
yeah I noticed that squeeking too but very slight... i can definately feel the battery cover move a little when I use the phone one-handed though. Guess nothings perfect! Should get new battery cover tomorrow....
GavinK151 wrote:yeah I noticed that squeeking too but very slight... i can definately feel the battery cover move a little when I use the phone one-handed though. Guess nothings perfect! Should get new battery cover tomorrow....
quick update: just got the replacement and it seems rock-solid! :icon14:
I am not sure what the diference was - I think maybe the little hole where the cover release button sticks out was slightly wider on the wobbly cover...
so if anyone else has the issue try these guys:
