right i cant get my gps to connect in my n95
i open slide then i open maps nothing happends
i ask it to locate my gps posistion it says no gps signal
i have v1.1 the gps lights in bottom right were just going flashing yellow ie no fix
i exit maps and went into tools gps data it says searching for satelittes
so i go into navigaton it says no satelittes
next i go into posistion it says no satelittes
next i go into trip distance no satelittes
so i press options satelitte statous it says gathering data
it then comes up with a few bars with numbers the bars are see through ie just empty bars with numbers at the start of them they dont move up or down but the numbers at the start of the bars do now and again
does any one know where iam going wrong??
iam not bad with phones but just cant seem to get this to wrk
any1 got a link or any help for me??/
please
nice1
do i have to activate gps
in maps i easily waited 10 mins for a gps fix nothing
my bluetooth gps picks up sats it like 30 seconds
Do you have AGPS enabled?
Look in Menu, Tools, Settings, General, Positioning, Postioning Methods.
1. First fix can take up to 30mins!
2. Ver12 OS gives Agps ability which improves operation.
3. Why on God's earth don't you do a forum search cos this has been covered soooooo many times! It's all there to find!
sorry pa mate but thanks for your help anyways
buxz777 wrote:sorry pa mate but thanks for your help anyways
Don't mind me! Having a bad day!
Lost my job, the cat left home and the wife came back; Doh!
Having never had a problem with the GPS I wondered what all the trouble is with getting a fix.
It was only after firmware update I noticed, I tried using tracker and it was taking for ever so I shut it down and tried the GPS Data Progrm and got a fix in a short time.
I dont know how the software works on this, does each piece of software have its own GPS Driver? So initial fixes could take diffrent time spans?
Or is the processor struggling with running maps and GPS at the same time?
If any on is struggling its worth a try anyhow.
Best
Gerrit
