Hi
I installed my aplication on a N95 device.
The application is detecting an outgoing call and than hangs it up by simulating the Red key press.
The problem is that after that , an incoming call is not ringing (and the mode is not silent or with headset).
this happens only when the call being hang up is called manually(not from contacts).
This problem occured only at this device,but only when my application was on.
on E61,and another N95 this problem does not occur.
** Could this kind of problem be related to software update :con?
* If yes - how can I see the software version and what is the latest software version for this device?
* If no - any ideas what can cause this?
Thank you very much 😊
