After installation, the icon for Y-Browser and Y-Task seem to be nowhere to be found. There're not inside Application folder. Its shows installed in the AppsManager. Or is it because I installed it on to memory card that cause this problem?
Any advise from kind soul out there????
Bareen31 wrote:After installation, the icon for Y-Browser and Y-Task seem to be nowhere to be found. There're not inside Application folder. Its shows installed in the AppsManager. Or is it because I installed it on to memory card that cause this problem?Any advise from kind soul out there????
On my N95 it is installed on the Menu page in a folder called "DrJukka.com" and you run it from there.
Ian
When I first installed Y Browser it too installed in a folder marked Yucca on the menu page. I then opened the folder and used Move to Folder to transfer the contents to my Office folder.
However when I installed the updated version of Y Browser I was asked during installation if I wanted to replace version *** with version xxx and it appeared in the Office folder I believe.
