Anti theft software for Nokia 9300
1 replies · 4,086 views · Started 29 August 2007
Dear all
I want to need an Anti theft software for Nokia 9300 for my personal use. If any one has this kind of software please send me the installation file. I will be very thankful to you.
mhashmi90 h o t m a i l d o t c o m
For Series 60 there is dedicated antitheft software, but I haven't seen any for Series 80 (9300/9500).
Series 80 does have some built-in protection mechanisms though:
1. Auto-lock the device if the SIM is changed. You can find this in the Control Panel -> Security -> Device security -> Lock if SIM card is changed
2. Remote locking. If your device is lost or stolen, you can send an SMS with a text you specified to the phone and it will lock itself (and the MMC) upon reception of the SMS. You can find this in the same dialog.
For normal protection you can also use something like PowerSecure, which has the option of showing a password dialog whenever you open the device.
Best regards
Arjen
BTW Asking for warez (and asking if someone can send you the installation file comes very close) in this forum is strictly prohibited. If you need software, try the shop link at the top of the page.
