Sup, i've downloaded d file & installed it n my phone but says itz not supported by my phone m runnin on ver. 4.39 i tot itz all gud in all ver 4xxx wat seems 2 b tha problem can anybody help?!
Color Palette Problem!!!
It wont work on some 4.xx phones.
And it can work on some 3.xx phones.
Maybe could be fixed on future versions? hopefully.
JyriK edit: Wording changed for better understanding 😃
So they got mixed up it works on most/some 3xx version & it doesn't work on all 4xx versions?! damn i want these app hope they can fix soon!!!
damn i tried it on my cuz phone ver 3.16 still doesn't work, anybody tried diz app, any luck?!
but mine is working my version is 4.37.
I think JyriK made a typo......
Look at this post by faquick:
http://allaboutsymbian.com/phpBB2/viewtopic.php?p=48977#48977
I have already read this. From what I understand it says that it doesnt work in all 4.xx versions but in some of them. Not that it doesnt work at all! The same is in 3.xx versions too.
Although I have the feeling we are saying the same thing....
Aww... so what should i do downgrade my n7650 from ver. 4.39 to 4.37?! ehehe damn i think derz nuthin i can do but stick with tha same ol, same ol, blue,purle n green, i've tried this program on 3 phones already mine 4.39, frend 4.39 n my cuz 3.16 but no luck, well m waitin 4 a miracle or fix! 😞
well, if anyone wants to try to "check" what to modify, contact me in private and I will tell you what file to edit and HOW to succesfully edit it without crashing your phone badly 😉
I'm on v 4.39 and it works like a charm.
i too can NOT use it on 4.39
I'm sure that faquick is on it right now.
to tell the trouth i missed the purple on my phone 😞
and it's working on my phone (4.37 home made update) like a charm 😃 😃 😃
it's working for me... 4.39 😃
ok people... beta is "floating" around a lot of ppl who asked me... if I have enough positive feedback in the afternoon I will release it on my website and on handango 😉
I have 4.39 and pExtender works.
I only noticed a minor difference: the three standard colors
display some menus with fading colors (eg. from blue on
left side of a menu bar, to light blue on the middle and
white on the right side of the bar), while the three new
colors don't have such fading effect...
Any idea?
mine 4.39, doesn't work. Faquick send me a manual way on how to do it but he warned me that the phone could go crashed in that. Still hasitate to try, if crashed, how to recover? Is it need a trip to nsc for re-flash or just a hard reset will do?
Hi cleo8888,
I am from SGP too. Just upgraded to v4.39 yesterday from v3.16.
Both could not work. Could it the fw from NSC not the same as others?
rdgs.
most likly it depend on NSC, singapore and philipines are using the same v4.xx(dont work), germany 4.xx (works)
[quote="cwleo8888"]mine 4.39, doesn't work. Faquick send me a manual way on how to do it but he warned me that the phone could go crashed in that. Still hasitate to try, if crashed, how to recover? Is it need a trip to nsc for re-flash or just a hard reset will do?[/quote]
My guess is that the worst thing that can happen is that in the end you will have to do a hard reset.
Notice the word guess 😃
Hi K,
Is your fw upgraded or comes with it in v4.39?
My 7650 comes with v3.12 then upgraded to v3.16 and yesterday to v4.39.
Have tried manually change the initialization file but still the same.
You mentioned about philipines, but some guys from there reported that their works.
faquick is still trying his best to find a solution. v4.39 can't have another sub-version. Or Maybe only v4.37 with red actually have more color palette embedded in the fw.
rdgs.
currently firmware work or dont work
Singapore - Dont work
Philipines - Dont work
Italy - Work!
Germany - Work!
any others?
I got mine upgraded from v 3.16 to v 4.39 and it works,i'm from Macedonia.
BTW: if anyone bothered to read the news Extended Profiles 1.50F from psiloc has the colour palette feature included and they say it works on all v 4.39 firmware versions.
Just download and installed Extended Profiles, still doesnt work!
hmm... :cry:
[quote="Theran"]Hi,
hmm... :cry:[/quote]
Well,now you have someone you can blame 😊
Mail psiloc about it,i'm sure they are working on something.
Yeah.
Though they took the Palette Extender from faquick and incoporated into their Profile Extender.
Until problem surfaces from the Asian region where our 4.39 doesnt work.
rdgs.
[quote="Theran"]Hi K,
.[/quote]
hi theran
i try both upgrade from 3.12 to 4.39 and new set with 4.39, all cant work. upgrade done in bugis nokia care
