In Notepad (on a computer), when you press the TAB key, instead of a single character space, a larger space is created (maybe this �larger space� has a name/term).
How do you do that on the Nokia E61 (When opening a *.txt or *.doc file with the built-in document viewer) ?
Thx:con?
It's called exactly like that: tabulator. In S60 you need to press spaces instead.
Does the E61 have a CTRL key? On the E70 you can use CTRL-009 (ie hold down CTRL then press 0,0,9 then release CTRL). It's clumsy but works. It's surprising that TAB is not available from the "insert symbol" function (ie when you press the "*" key).
Damn it, my E70 has alot of other characters!! desertrat, the whole character map from windows it's here!
desertrat wrote:Does the E61 have a CTRL key? .
yes it is 2 to the right of the space on a UK keyboard.
