Private SMS & Call Guard - Hiding MMS ?
9 replies · 15,467 views · Started 11 September 2007
I have Private SMS & Call Guard from symbianon, works fine for calls and SMS, but doesn't seem to hide MMS in the same way...is there a setting I'm missing ?
(Emailed symbianon support...)
Hi, I have the same problem and would love a fix so please post what you get back from the developer.
It would also be great if messages from people on the 'babylist' didn't use the normal message alert tone.
I occasionally see texts to people on the babylist appearing in the log but it only seems to be the most recent one and then it disappears randomly at some stage. I'm not sure I understand how it manages the log aspect.
All in all, this is a good product though - just could be a little better.
secretsquirrel wrote:Hi, I have the same problem and would love a fix so please post what you get back from the developer.
Will the makers ever update it?
secretsquirrel wrote:It would also be great if messages from people on the 'babylist' didn't use the normal message alert tone.
Hi, This is the killer application you;ve been waiting for 😉 I've emailed the developers and suggested that they add a feature to vibrate the phone on a particular contact in the next version too and got reply saying they would defo add this! You can download it here
On another note has anyone else had problem with Call guard where you get the message 'Invalid Data File' when you set the application to autostart? This is annoying because i then have to start it manually. Also i've noticed that the application closes itself whenever i send an MMS message. As you say great application but could do with improvements
Regards
Paul
trianglethief wrote:Hi, This is the killer application you;ve been waiting for 😉 I've emailed the developers and suggested that they add a feature to vibrate the phone on a particular contact in the next version too and got reply saying they would defo add this! You can download it here
Regards
Paul
Sorry for dragging this up.. Is it worth paying $19.99 for it? i didnt realise there was a pay version.
This product seems perfect, Is it official website is symbianon.com/page/pcg3rd.html? thanks.
I have the same issue, thanks for sharing those sites I will try them I bookmarked them already.
