this is a new app released for the P800 by FreEPOC.
jRC4 is a small file encryption utility written in Personal Java. It will encode and decode files using the secure RC4 algorithm. jRC4 can protect your sensitive data. It was particularly written for users of the P800 smartphone, so that sensitive data which has been downloaded from a PC (for example Word or Excel files) can be encrypted to protect the contents should your smartphone be lost. However with knowledge of the original password, the contents can easily be decrypted and viewed on the P800 Viewer. Unlike some other protection software written for PDAs which uses proprietory file formats, jRC4 will encrypt or decrypt any file. Because jRC4 runs on a number of different platforms (anything which runs Personal Java) you can always access your data. jRC4 is freeware, This is the first version, I posted it here. :P
There is more coming for the P800. 😉
