HAS ANYBODY OUT THERE FOUND A DECENT BATTERY UPGRADE FOR THIS FONE OR HAS NOKIA RELEASED A MORE POWERFUL ONE?
THERES LOADS ON EBAY BUT I DON'T REALLY WANT TO BUY ONE THAT IS'NT A GENUINE NOKIA ONE AS FROM PAST EXPERIENCE WITH MY N80 THE ONE I ENDED UP BUYING WAS WORSE THAN THE ORIGINAL ONE.
ALSO DOES ANYBODY KNOW IF NOKIA SELL A DESKTOP CHARGER FOR THE N95?
tHANKS
:con? :con?
Caps lock button stuck in is it?
1) don't shout.
2) don't yell.
3) like #1
4) there is no other original nokia battery available for our N95, or you could see it by searching in the Nokia site..
5) it seems that nokia won't build a desktop charger. maybe third-parts will do it.
1) don't shout.
2) don't yell.
3) like #1.
What does that mean cinghialino?
means that you need to read some "netiquette"
writing in all caps means to shout.
cinghialino wrote:1) don't shout.
2) don't yell.
3) like #1
Haha, I love it when someone kicks up a fuss about someone else writing a post in caps. The concept that writing a post on caps is the same as walking into a room and yelling at the top of your lungs makes me laugh every single time.
OH WELL, EACH TO THEIR OWN!!!!!!
:tongue:
But seriously, Nokia don't do a desktop charger at the mo. I found this one on mobile fun, ttp://w w w.mobilefun.co.uk/product/13910.htm.
Its not bad but you need a powered USB hub if you wish to connect the phone to the PC and charge it at the same time.
Hope this helps
Steve
So no good replacement batteries then?:con? :con?
starbubble82 wrote:So no good replacement batteries then?:con? :con?
I am surprised that you did not already know that after SEARCHing the AAS Forums.
Nobody has ever made a cheap replacement battery that was better than the one supplied by the handset manufacturer. eBay ones are always poor substitutes.
If you cannot charge your N95 regularly during the day, buy a Genuine Nokia battery and a desktop charger. 😉
