E90 wierd problem!
3 replies · 3,386 views · Started 29 September 2007
i bought E90 last month..and today i have a problem..once the unit is switch on all ok but once i press any single digit at front and i will see the display will show 698 and the cursor keep on running..i cant answer from front panel but i can use from inner keyboard. I have updated the ssoftware fearing to any kind of virus but in vain...anyone out there have come accross similiar problems please do share with me..in simple words i cant use the front ponel keys except for the power button.
Thank You.
Hi ekbal,
Have you checked if there's something stuck in the keypad that would cause this behavior. If none, better rush to your nearest Nokia service center and have your phone checked. :icon4: Don't forget your receipt/proof of purchase.
Hope this helps. Thanks.
I also think that it must be some keyboard problem. Hardware problem.
I had a similar problem with another phone some time ago, and I remember that Nokia replace the keyboard and its over.
Good luck.
why is taking so Long
& for no other phone Just This one 😞
Cant wait any longer keep telling myself get another But when i compare it to E90 NOTHING beats the Nokia
Please give some Info when can we get it in USA ?
