Anyone found an application to make loudspeaker stronger for call conversation??? The trick with voice-tag doesn't do much improvement. With Smart Answer you can hear really loud!!!
Soft loudspeaker...
Oh not again. :x
Not another speaker related thread...
No there isn't.
And register yourself, it's free :roll:
[quote="Anonymous"]Anyone found an application to make loudspeaker stronger for call conversation??? The trick with voice-tag doesn't do much improvement. With Smart Answer you can hear really loud!!![/quote]
what do you mean? the voice tag trick works wonders for me. try it again. make sure you do it once - to ensure that restart your phone. if you do it more than once it really wont work. so far that is the only solution for the speaker problem. 😊
whats the voice tag trick. plz tell me too. i use a lot of loudspeaker as well.
The trick is there in the forum. Please use 'Search'. Anyways what you can do is restart your phone. Then press the button to activate using voice tags and speak a wrong contact. The phone would say 'No Match Found!' Now try making a call and see the HUGE difference in the voice quality......
Cheers
CJ
hahaha, everytime i come to the main forum lobby, i always see something about soft speaker
Hmm I think I will try it.
Please all, use Search before posting!
There are 2546 topics in this forum at the moment, your problem must be in one of those topics. if not, feel free to post 😊
agreed
thanx its work with me the loud speaker 😃
