S60.com do like to license and give away free utilities every now and then. This month, they've just put up Aglaya's Call Filter (normally $9), as the name suggests a piece of software to filter through just the calls you want, according to ruls that you set up. It's compatible with all S60 3rd Edition smartphones. Grab it while you can!
For some reason I'm not seeing this on the link you posted. Is anyone else having a problem?
You need to sign in to s60.com for the link to work.
The call filter you are talking about not found, leave the right link, or the right explination. Utilities not found, call filter at all.
Signed in and went to My Exclusives.
Then selected Utilities and there it is.
Whats the problem?
Thanks Andy, I should have thought to check..... 😊
