I have installed this software in my 9210 but don't run!! Help me!!
Problem with Space Taxi game
That game needs all the memory you can get, reboot your phone and then run it, you might get lucky, try closing all the things like desk/phone/extra/office if it still doesn't work
I have closed all task and not work
:cry:
this is a image of my desk, I nedd more memory for this game?
I needed 40% :s killed even desk after launching space taxi, to be honest, the game isn't worth it ...
Thank you!
[quote="black biker"]I have installed this software in my 9210 but don't run!! Help me!!
Thanks[/quote]
SpaceTaxi needs JAVA... have u install it???
anyway, SpaceTaxi seems to run smoother/faster on the 9210i machine...
p/s: 😉 well... like what Dazler said... u wont miss much if u still cant have it running...
:roll: and also if i'm not mistaken, your firmware have to be 3.62 or higher to run it...
I have a 9210 with firmware 4.13 and Java installed...
This program is only for 9210i?
someone has installed it on normal 9210?
😉 It's for both 9210 and 9210i...
I have installed it on my 9210 and i have to restart my machine and also turn off some off my memory consumpting apps to run it... its really a pain in the ass... anyway my friend have it on his 9210i and is much easier to load it... no restarting needed... thats one advantage of 9210i... it can run JAVA apps better than our 9210...
i have a 9210i, how do you install java?
also, what's my firmware #, how do know my firmware #?
thanks...
Press *#0000# on the phoneside to check your firmware ... but since I have one of the oldest firmwares 3.18 and was able to run the game, you won't have to worry about that 😉
and u should also not worry since u already got the 9210i...
it should be workin fine... 😉
thanks 😃
