helpppppp me plsssss
5 replies · 2,029 views · Started 26 January 2003
😮 hey
i have almost evry 7650 software thr is
but i still dunno how to send zip files to da fone
i hv an IRda connection
i hv seleq ,efileman,zipman,file manager .....but still cant get my zip files to da fone
isnt thr sum proggy which allows me to drag n drop files between my pc and fone..
n i wanna send my movie files to da pc 2 but tht dusnt work either :cry: :cry: :cry:
how do i send any file to my fone inbox thru IRda??
plss hellpp me u guyzz
Why do you send the zipped files to your phone?
It might be good idea to unzip the files on PC first and then send just the sis files.
There is coming soon a program for PC for browsing the phone, and sending any file to it.
But your problem seems to be that your IR connection doesnt work?
nooh my ir connection works n i can install all da software
but i wanna send gameboy roms to da fone
I assume you're using either Windows XP or 2000?
1. Connect to your 7650 via ir
2. Right-click on the zip file, select "Send to..", and choose "A Nearby Computer".
The file will be sent, and will appear on your phone as a new SMS.
If this does not work, right-click on the mRouter icon, choose properties, uncheck the Infrared option, and Close. Try step 1 again.
Remember to re-enable your infrared option in mRouter when you're done.
[quote="JyriK"]
[/quote]
WHEN?
😮 WHO IS THE DEVELOPER? :cry:
I WANT IT MADLY......... :x
:black: :black: :black: :black:
