Sky Remote Record s60 3rd edition
21 replies · 5,828 views · Started 29 December 2007
Does anyone have the sky remote record app (sisx file), as I own a N82 and believe the file for the N95 will work, however, I cannot download it from Skys website as it says my phone is not compatable and I dont want the java app 😊
dont seem to be able to find the sis file... or intercept it to get it for you...
I did have a copy sometwhere...
I do have a sky anytime app installed on my N82, is this the remote record app, I have tried putting my username and password in it, but then it fails to connect to the server. 😡
Exact message says..........
connecting to network.................
connecting to server....................
LOGIN FAILED
unable to find server. please confirm you have selected the correct access point
this is not a problem with my connection
I have the SKY Anytime S60 app. Drop me a PM or email via the panel and I'll mail it over, the file is too large to attach to a post here.
It works fine on my N82.
just tried to connect and it just sits saying connecting for a while then times out.
good old sky
Having similar problems connecting with my N95 - i attributed this to my having updated the firmware recently.
However, despite a complete update of all my web access settings it would appear that the fault may lie at the Sky end if lots of us are getting the same error message.
Weird. I used the application about a week ago and it worked fine. Updated my N95's firmware, reinstalled the application from the Sky website, try to login today and it just times out. Same error as the rest of you here.
Same problem for me. Anyone with the old firmware who can see if its still working for them? That way we may know if its a "feature" of the new firmware.
Jay3gsm wrote:I have the SKY Anytime S60 app. Drop me a PM or email via the panel and I'll mail it over, the file is too large to attach to a post here.
Hi guys, i'm looking for the SKY Anytime S60 app, can someone please email it to me - [email][email protected][/email]. In desperate need of it for my N82 as I don't like the java version i'm currently using.
Many thanks in advance.
Even if your phone is not listed as working, you can get the version for N95 link sent to your phone by sky free.
so long as your mobile is supported by sky.
If it isnt , you dont get it.
Or at least, if sky thinks it isnt... you dont get it.
Yes, having to use the Java based version until they sorted themselves out with an S60 3rd Ed. version was a pain 😉
