Bluetooth Detection?
1 replies · 2,038 views · Started 26 January 2003
In the Bluetooth examples that come with the Series 60 API the applications check if Bluetooth is turned on and present a prompt to the user to turn it on if it currently is turned off. I would like to do this, but I cannot figure out how this is being done in the examples. Can someone let me know how this is done? Thanks!
I thinks it will be displayed automatically when you are trying to create a connection if your have Bluetooth off.
