Can E90 use larger than 4Gb micro SD
6 replies · 6,085 views · Started 30 December 2007
I have been told that an E90 cannot take an 8 gig micro SD card - 4 Gb max. Is this true and/or is there a workaround?
clamcontrol wrote:I have been told that an E90 cannot take an 8 gig micro SD card - 4 Gb max. Is this true and/or is there a workaround?
If it supports 4GB cards, it has a SDHC-compliant card reader so you should be able to use cards up to 32 GB some day. Currently, the largest SDHC card available is 8 GB.
Yes it does..I've been using a Sandisk 8gb microsd for over a week now without problems.
