The Pdf products from mBrain Software for S60 3rd Edition have received an upgrade. Most notable is v1.75 of Pdf+ Pro, which includes the functionality from PdfPrinter, allowing you (as it sounds) to print to PDF format, and also lots of Nokia E90 keyboard shortcuts. Pdf+ Standard v1.75 is also new out today. Pdf+ Pro is a paid upgrade to the Standard product.
As the author of Pdf+ I would like to clarify the different editions of Pdf+ that are available nowadays. There are three editions, Pdf+ Basic, Pdf+ Standard and Pdf+ Pro.
There are also two upgrade packages, Pdf+ Standard Upgrade and Pdf+ Pro Upgrade. Standard Upgrade turns Pdf+ Basic into Pdf+ Standard. And Pro Upgrade turns Pdf+ Standard into Pdf+ Pro.
Buying Pdf+ Pro, or buying Pdf+ Standard first and Pdf+ Pro Upgrade later makes no difference, not in functionality and not in price. You can for instance buy Pdf+ Standard for your N95. If you later purchase an E90, you can then use Pdf+ Standard on the E90, as expected. If you also want printing support, you can just buy Pdf+ Pro Upgrade, and you have spend as much as if you have bought Pdf+ Pro in the first place.
The same reasoning works for Pdf+ Basic and Pdf+ Standard.
Sander van der Wal
www.mBrainSoftware.com
