Nokia Software Updater Error On Vista
6 replies · 25,974 views · Started 18 January 2008
i am trying to check if there is an update on my E90 and when i run the nokia software updater i get the error" Nokia service layer host process has stopped working' bla bla bla. this is not only on version 1.4.0. en but also on older version. probably something to do with vista.
please help!
Hi spycorfu
All i can say is that i have been able to update my E90 and my Laptop is running Vista Home Premium and NUS with out any problems at all.
Marc
Hello,
I've had problems with nsu on vista before. I 've figured out, that the Internet connection sharing service prevents the nsu to work properly. Go to task manager and stop the service.
Cheers,
That's it ... that's totally the reason it didn't work for me ... Internet Connection Sharing
BUT ... you cannot stop the service in task manager if you enabled it from the regular connection preferences window ...
You will need to go to your network connections ...
And then, from the right click menu on each connection, select the advanced tab, and then look for the internet connection sharing section and uncheck it
Now, before restarting Nokia Software Updater ... which should work fine ... just to be sure ... right click the desktop icon / shortcut ...
... select properties ... and then the compatability tab ...
Now check Run this program in compatability mode for Windows XP (service pack 2) ....
And then apply and then open the Nokia Software Updater ...
You should have a straight through solution !!!
