What method of synchronising do you use?
3 replies · 2,465 views · Started 18 January 2008
I am wondering what is the most popular amount S60 owners. I use Outlook, but is there is anything better available.
I read the Google Sync review but it does not seem to sync with to do or notes, so I have ruled that out.
I dont use Outlook for my email, just use it to sync my contacts and calender items once a week or so, in case my phone falls over, or is nicked etc.
Always worked fine for me, so no need to change it IMO.:icon14:
moonshot wrote:What method of synchronising do you use?
Depends on what your purpose is. Is it backup or constantly making sure you are in sync between various systems?
I use a variety of systems
* Salesforce.com (our CRM system)
* Evolution as my primary email/PIM client (on Linux, what my laptop is running)
* Microsoft Outlook running on a PC at work that I never use but I keep it there because Salesforce.com hasn't released any way to sync with non-MS tools
* Scheduleworld.com with SyncML to sync w/Outlook, Evolution and phones (E90, others)
Scheduleworld works well, I would say, and the benefit is that it syncs over the air. You can also have Scheduleworld publish to Google calenders etc.
