Just wondering if there is a alt-tab type feature - I can't seem to
find it and going back through the menus to to access applications
that are already running seems a bit clumsy.
Thanks,
Adrian.
Thanks,
Adrian.
RTFM? 😉
Press and hold the key to the right of MY OWN.
Alternatively, use Chr + Tab.
Hi, thanks for your reply,
Yep I should have read the manual a bit better. The button
the right of My Own just goes into the applications but
Chr+Tab does the trick nicely.
Incidentally, I found some really great software called
'Task List'.. I recommend people take a look.. you configure
it to popup when you press the left hand 'configurable' key
and it's a nice task switcher too showing memory usage
by applications etc.
Seeya,
Adrian.
If you press once it brings up the applications, but press & hold for a second or two and it brings up the list of running tasks.
I have been using "Tracker" to show recent programs, running programs and free memory, but it does seem to slow the system down. 😞
