Problems with SkyQuiKey on N82
1 replies · 3,741 views · Started 30 January 2008
I am using SkyQuicKey since it was first mentioned here on AAS. It is one of these must have applications. Once you have been using it for a while, you cannot do without. Not even the new advanced search facilities on the N82 can replace SkyQuicKey.
However, the application frequently freezes my phone. I then have to reboot the phone. I cannot reproduce under which circumstances the application shows these problems.
Already when I was using my N73 every now and then the phone froze and a reboot was required. It improved after I installed version 1.01 but now that I switched to the N82, the problem becomes worse.
Currently, almost every day I have to reboot the phone, which makes it almost unusable. Does anybody know a cause or workaround?
Tom
Can't help with your issue, I can only say I never experienced issues with that app on the N82.
I stopped using it because certain actions did not work properly with the app, things like setting a four digit code to connect via Bluetooth. I binned it in the end. I would hope Nokia can add something similar to SkyQuiKey natively to the S60 OS on future handsets
