i was talking to my gf and the phone hadn't moved at all .....it was on my moms end table completely flat....and it randomly turned off.....i thought it was hibernate or standby mode but no its off in my menu>settings.
now its happening more and more often like 6-10 times daily.
whats wrong?
random restarts with my n73?
bwomp969 wrote:i was talking to my gf and the phone hadn't moved at all .....it was on my moms end table completely flat....and it randomly turned off.....i thought it was hibernate or standby mode but no its off in my menu>settings.
whats wrong?
bump
have u upgraded the firmware recently?
if you havent then do that first see if it solves the problem, if you have upgraded recently then there was a firmware which was pulled after a few days because there was some reports of problems with it-think downgrading is best bet to fix it.
OK..I had the same problem + phone being v slow.
It is due to some of the software/themes u might have installed from "unofficial" websites.. (i.e. a TomTom u have downloaded..)
Couple of good solutions:
- reconsider all the software u have installed / themes and remove what you are not using.
- reconsider all random files u might have on you phone/memory card - making more space on your phone/memory card is always a good thing.
- most importantly update the firmware from the nokia website but please note - it might not recognise all the applications u have installed. In this case u will have to look in your explorer and find the installation files and install them again! they are still on your phone just re install them. Please note that a downloaded version of some applications (i.e. Tom Tom) might not work anymore. When u try to re install it it might say that the certificate has expired and it looks like there is not solution 😞 I am still struggling with that but I will post a thread if I can make it work again.
PLEASE NOTE - It is important thatu do what I suggested: MY PHONE DOES NOT RESTART, GO SLOW OR DO FUNNY THINGS ANYMORE!
Good luck, take care of your n73 😊
alright so how do i revert back to an older firmware?
bwomp969 wrote:alright so how do i revert back to an older firmware?
You, er, can't. :frown:
i think if u have the firmware which was subsequently pulled u can downgrade but not sure.
in reference to morena84 which says the certificate is expired on his apps-just change the date back to a time when the certificate isnt expired and install, then change date back.
