Nokia N95 Versions
5 replies · 4,877 views · Started 22 February 2008
Hi Guys,
I final gt round to plucking up enough courage to making a post. So don't bite my head off...
I am hoping to purchase a nokia n95 on contract in the UK.
I am hoping that you can help me out by telling me the differences between the normal N95, N95 8GB and The N95 US.
Is the N95 US just a remodel N95 8Gb and does the standard N95 8Gb have a camera cover or not, or even a better battery.
Any Images showing this would be great.
Thanks In Advanced 🙄
Oracle
ORACLE wrote:Hi Guys,
.........and does the standard N95 8Gb have a camera cover or not, or even a better battery.
Oracle
No, and it doesn't matter. And definitely, yes.
Suggest you google on Nokia N95 8Gb, and all will be revealed. Good piece of kit!
KN
Oracle
Normal N95:
Memory card slot, camera cover, poor battery capacity, 56 mb of internal RAM
N95 8GB:
NO memory card slot but 8GB built in memory, NO camera cover, better battery capacity, 128 mb of internal RAM
N95-3 or The US version of N95:
Exactly same as N95 8GB, except for the fact it CAN run on American HSDPA frequencies, practically no use buying this unless you live in the US AND you are a data user.
I hope this helps you in deciding.
sbm007 wrote:Normal N95:
N95 8GB:
thanks that answered all my questions
cheers oracle
N95 8GB:
where the 3G of Normal N95 can be used, Europe only ?
