Sunrise - Steve's 'Ultimate' theme
14 replies · 5,957 views · Started 06 March 2008
You'd think that I'd be satisfied with the hundreds of quality S60 3rd Edition themes out there? Nope, I was on a quest, a search for my 'ultimate' theme, and I had a long wish-list. In the end, I chose to commission PiZero to create it and 'Sunrise' is the result. Happy downloading and all comments welcome!
More themes could benefit from Steve's theme criteria. Including some of the original Nokia themes too. One thing though, the yellow really does not match well with my delicious plum shell. The problem with most themes anyway.
Regards,
Snoyt
Nice seeing someone that also dislikes personalized icons!
Cheers Steve!
Looks a bit "George Hamilton" or David Dickinson inspired, if you know what I mean 😉 but nice to see more simplicity. However, I will stick with "Sand", from the same designer.
Steve,
I tried downloading this directly on my E90 and it wouldn't install (went directly to Notes). Perhaps you can make it a .SISX file?
Lark
hi steve
i'm afraid i can't agree.
i like much more the carbon 2 theme from PiZero with changed icons.
i mean because you can put a default theme and put a sunrise as wallpaper.............and then you have the sunrise theme.
the beauty of themes is because they change everything (wallpaper_icons etc)
Yuk Yuk Yuk, I supose if you like the simpsons its ok....Looks like someone has thrown up over my N95!
I like the princible though, something you can see outside, with standard icons. Hmm, whats wrong with the default?
Ducks.......
David
I'm getting a certificate error.
I know I have to change something in my settings on my phone, but I can't remember what. I did it once last year, but I've reset my phone since then. When I try to google the answer, I'm not finding what I need.
Can someone either point me in the right direction or tell me what to google?
Great theme Steve. Infact your criteria is just perfect. I've been using ICE by PiZero recently and like to switch to the more cheerful Sunrise every now and then. However, couple of (somewhat annoying) bugs I wanted to bring to your attention.
1. In the built in clock, if I try to manually set the clock, the parts time field being edited does not show as highlighted. This is not a big deal since I have my clock being updated automatically by the network, but ...
2. I use the Handy software quite a bit, espeically the handy calendar. In that software, anytime I add an event, in the edit mode, the date and the time fileds are not highlighted. So it becomes a bit of a guessing game and can be annoying at times.
Any chance we can get the master to fix these bugs? Fantastic theme otherwise!
