Free Calendar
9 replies · 3,348 views · Started 17 March 2008
does anyone know of a free app for windows vista that will sync with my N95 8Gb calendar? It doesn't work with MS Works Calendar and I don't fancy spending �350 on a MS Office just to get Outlook.
8Ball
there is a app what allows you to sync your mobile calender with your google calender
its freeware too go toofficial google site for more info
randomfan wrote:The latest verion of PC Suite should allow you to sync with Windows Calender, which is part of Vista.
What version do you have? I've got the N Series PC Suite 2.0.262.0 from the Nokia site and there's no option on the sync wizard for calendar.
8Ball
8Ball wrote:What version do you have? I've got the N Series PC Suite 2.0.262.0 from the Nokia site and there's no option on the sync wizard for calendar.
8Ball
You are using the N-Series PC Suite which doesn't sync with Vista calendar.... the normal version 6.85 does :icon14:
OK, so do I have to uninstall my N-Series suite or can I install the standard suite alongside?
I have n-series suite on my work pc and PC suite at home, both Vista machines and both sync with Windows calendar.
