phone has crashed
3 replies · 1,846 views · Started 02 February 2003
i installed wildskinz then took it off now when phone is switched on all i get is system errors on every application switched it on/off took battery out nothing cant get in to the phone at all when i switch it on it displays sytem error press any button system error cant get into anything im taking phone to the nsc 2 morrow perhaps they will send it away and ill get a 4.39 upgrade but i just want my phone to work... on 3.12 any ideas or should i take it straight to the shop
Have you tried to install the app again? And uninstalling.
Might wanna try hard reset before taking to NSC?
It *should* repair that, maybe 😃
Locate my post before, its about Start Up bypass. It should have your phone go to Phone mode for you to do Hard Reset.
