Does anyone with an E51 use the Screenshot app? I find that with the edit (pencil) key now part of the # key, it isn't so striaght forward to take screenshots anymore. The only working configuration I can get is to use the backspacekey, which works, but of I forget to close the app and then need to use the backsapce for its legitimate use, I end up taking a screenshot instead! It can be very frustrating sometimes.
Soes anyone else use Screenshot? How do you get around this usability problem?
Jay3gsm wrote:Does anyone with an E51 use the Screenshot app? I find that with the edit (pencil) key now part of the # key, it isn't so striaght forward to take screenshots anymore. The only working configuration I can get is to use the backspacekey, which works, but of I forget to close the app and then need to use the backsapce for its legitimate use, I end up taking a screenshot instead! It can be very frustrating sometimes.Soes anyone else use Screenshot? How do you get around this usability problem?
Hi Jay3gsm,
I use the Screenshot application quite a bit and must admit that I now use the "backspace" key however I used to use the "#" + "*" keys which worked very well and of course can be chosen in the "settings" of the application.
The reason I went onto using the "backspace" key is that it is just a "one key to press".
Regards. :icon14:
