Is there any way to put the screen saver out of landscape mode and make it portrait mode? I'm sorry ahead of time if this is a repost. I checked the forum and no one had a same post. Thanks.
Screen saver in landscape mode
chungdae wrote:Is there any way to put the screen saver out of landscape mode and make it portrait mode? I'm sorry ahead of time if this is a repost. I checked the forum and no one had a same post. Thanks.
I'm afraid not - I contacted Nokia by email with the same question and got this rather helpful (not) reply from them!
With regard to your email, kindly be informed that the features, functions and design of Nokia mobile phones are influenced by the Nokia's business decisions.
Nevertheless your feedback is valued and this will be highlighted to the relevant department within Nokia UK for further consideration.
Kind regards,
Dan N
Nokia Care
i havent found this either. its very annoying that the 8GB has screensaver in landscape mode.
Great. Thank you.
I quite like it that way. cClock looks great in landscape.
Yep i found it really annoying as i didn't know there was a problem with this so i made some animated screen savers 240x320 about (16)of em.
Then i put them all on my phone activated the 1 i wanted then when i looked it had miniaturised my screen saver in to landscape mode and looked very horrible and most the screen savers i found since had been made in the same way as mine and they was just as bad.
Half the ones i brought dint fit the screen properly too,The wapsite claim they are 320x240 but i think they are not as there is a little gap down each side they look more like 300x240
