[b]9210 Help me please[/b]
7 replies · 1,598 views · Started 03 February 2003
😮ops: HI...
Please help me in this problem!!
I installed the APPFORGE in my 9210 and this program fuck my control painel, install / remove program and mediaserver.
Than i can�t remove anything in my 9210.
What can i do to safe to this problem????
I Have problems with the remotelinkcontrol too, than i can install anything...
Try reinstall the appforge....I still have doubts that this can cause you this problem.
First restart your 9210 bt removing battery for 1 or 2 minutes.
If does not hel, try reinstall appforge.sis
I did what you saw and nothing ...not resolt... dont work
tanks for all......
I installed appforge in my drive d:. Thats Correct???
APPFORGE Version 3.2.0 to NOKIA SERIES 80.
Can you send me you version to see if my 9210 works well ???
My E-mail : [email protected]
Fernando Nogueira
Portugal
Thans For all.....
Sorry, but my english is very bad.....and with many errors!!!!
The problem here is not to reinstall appforge but to actually reinstall your system first... then only the appforge... coz your system already got corrupted...
if that doesnt help... try deleting your .ini files... remove battery... wait for couple of seconds... put it back... When you see the Welcome screen, immediately press and hold down the Ctrl+ Shift+ I keys. (The I key should be pressed last.)
T
Your temporary files are now deleted. This empties the cache, removes cookies, resets plugin registrations and resets the settings you have made in some of the applications including all Internet and profile settings, Desk shortcuts and display settings.
😉 All other applications and files stay intact....
