Nokia N95 8GB V.20 Auto Rotate
4 replies · 6,493 views · Started 09 April 2008
Hi
I have just upgraded to the v.20 firmware, anyone know how to start the auto rotate feature. Please advise. Thanks
Tools -> Settings -> General -> Personalisation -> Display
And then there's the "Rotate screen" option
Thank you for the reply, but it doesnt seem to work i rotated the screen both ways it didnt work is there anything elso to it than that.
odd.. you're definitely on N95-2, with 20.0.016 (or whatever number it is) firmware?
it should only rotate if you turn it to the left, i.e. the same way it'd be normally with media keys out.
definitely doesn't do it on any screen?
