Nemesis problem
20 replies · 17,988 views · Started 09 April 2008
I want to debrand my nokia N95 8GB but I keep on having a problem. I have installed the drivers from the phone aswell as the nokia pc suite. Nemesis has also been installed. The problem is that when I use the Nemesis and come to scan for phone info, I get a message along the bottom saying "scan for product....error. I am using win xp but I have installed the software and my phone on a leptop with vista home premium and I get the same problem. Can anyone help??????
Hi this problem has been discussed in previous posts but the way round it that I found is to restore your sytem to an earlier date then you upgraded the NSU - this way NSS will work so you can change your product code to the Norway one like I did, then re-install NSU again in order to update then you'll have to restore again in order to change your code back to the Euro 1.
The reason NSS no longer works is because of the Nokia Software Updater new version.
seki wrote:http://www.allaboutsymbian.com/forum//forum/thread/71546/
There does seem to be a problem with the latest PC suite drivers.
My suggestion is remove PC Suite .. install the version that came with your phone .. do the Nemesis change .. then you'll need the latest PC suite for the firmware update.
Good Luck!😊
I was going to try that next tbh becuase the first thing it asks you to do when you instll the pc suite is to update the Nokia updater. I will give it a bash and post the results back in this forum.
Agree with Baconroll. Also, there are known issues with some versions of Vista too, but these recent issues are mainly down to using the latest version of PC Suite.
I had loads of problems with NSS with Vista and XP.
My solution was to update all software to the latest versions.
Run NSS with the phone NOT attached. Take the battery out of the phone for a few seconds, put it back it, connect cable THEN swith the phone back on. Vista and XP both then detected new hardware, installed the correct drivers and both NSS and NSU both worked.
It took me three solid days of trying but I finally got the Vodafone crapware off my phone.
GSi-R wrote:Agree with Baconroll. Also, there are known issues with some versions of Vista too, but these recent issues are mainly down to using the latest version of PC Suite.
I uninstalled all the nokia stuff an nss and installed it again but when I got the pop up telling me that there was a new updater, I chose not to download it. As soon as I went into the nss and phone info, it picked my phone up right away. Everything went well until I went to use the nokia updater. It said I could not use the updater without first having upgrading it. I did so, the upgraded the firmware on my phone. It still had the o2 rubbish on, nothing had changed apart from the firmware. I tried all over again and sure enough, when I scan for my phone info, i got the scan for product.....error again. Is there anyway round using the nokia updater without having to update it?????? Any help on this is very much appreciated
BigCol wrote:I uninstalled all the nokia stuff an nss and installed it again but when I got the pop up telling me that there was a new updater, I chose not to download it. As soon as I went into the nss and phone info, it picked my phone up right away. Everything went well until I went to use the nokia updater. It said I could not use the updater without first having upgrading it. I did so, the upgraded the firmware on my phone. It still had the o2 rubbish on, nothing had changed apart from the firmware. I tried all over again and sure enough, when I scan for my phone info, i got the scan for product.....error again. Is there anyway round using the nokia updater without having to update it?????? Any help on this is very much appreciated
what did you change it to? bear in mind .. you're using 2 (two) pieces of software here at least .. check this http://www.youtube.com/watch?v=uN9eRlddfH0 .. read the instructions .. probably the single biggest error people make is neglecting to check the writeable box ..
If Nemesis changes your product code then doing the firmware upgrade will result in NO O2 "rubbish" on your phone.
The latest version of the NSU is installed as part of the upgrade process.
I strongly advise a hard reset before you try doing the firmware upgrade.
This new method is safer but at least a reset will remove any weird settings you may have.
With ALL of this stuff use "PC SUITE mode".
Good Luck!😊
seki wrote:what did you change it to? bear in mind .. you're using 2 (two) pieces of software here at least .. check this http://www.youtube.com/watch?v=uN9eRlddfH0 .. read the instructions .. probably the single biggest error people make is neglecting to check the writeable box ..
Good Luck!😊
How do I do a hard reset????? As I said when I first used the Nss it worked fine and picked my phone up but as soon as I opened the NSU up, it told me that i had to update the NSU before I could upgrade my phone. At this point the nsu told me to disconnect my phone from my pc which I did. When I conected it again, I was able tp update my phones firmware to v15.0.0.015, 11-12-07 but my phone still had the O2 fw on it. Could it be something to do with the latest NSU?
You USE NSS to change your product code to something that ISN'T an O2 product code - more likely a EURO1 code - THEN you update it with NSU, which will give you the latest version of the FW.
use 0549487 - EURO1 .. since thats an 8G code .. in Nemesis .. check that its been changed by re-attaching it and asking Nemesis to scan again.
IF it hasn't changed .. make sure the write box is enabled
hard reset is holding GREEN and 3 and * while turning on .. it is hard to do .. for a reason!
Finally there is a new version of PC Suite and in it NSU ..
Good Luck! again😊
Got mine working at last, in process of changing product code now.. If it's any help to anyone, uninstall the nokia cable drivers and then connect the phone to pc again. It will search for new hardware and use the software disk that came with phone to install new drivers. NSS and software updater now working together again : )
That didnt work matt64. I did upgrade my phone but I still have the crappy O2 stuff on it. I have followed everything that has been posted in here BUT still I have the o2 on my phone. Can anyone help
BigCol wrote:That didnt work matt64. I did upgrade my phone but I still have the crappy O2 stuff on it. I have followed everything that has been posted in here BUT still I have the o2 on my phone. Can anyone help
if your phone has an o2 product code and you have not changed this... and you update, you will still have o2 branded firmware.
that you haven't changed the product code - if you had managed that then you would not get the "crappy O2 stuff" .. since the new version of the firmware for EURO1 does not contain it.
Hate to repeat this but - when you are in the Nemesis Service Suite - you MUST click the Enable box next to Product Code - change it to 0549487 .. then click the write button ..
Once you can confirm that the code has changed then you can do the update.
seki wrote:that you haven't changed the product code - if you had managed that then you would not get the "crappy O2 stuff" .. since the new version of the firmware for EURO1 does not contain it.
I think I know were I have been going wrong. when I enter 0549487into the box then enable I have actually been entering 0549487-euro1 believe it or not. What a tit head. I am just upgrading my phone now.....fingers crossed :embarasse
BigCol wrote:I think I know were I have been going wrong. when I enter 0549487into the box then enable I have actually been entering 0549487-euro1 believe it or not. What a tit head. I am just upgrading my phone now.....fingers crossed :embarasse
[SIZE="6"]yippeeeeeeeee. get the f*&K in, you beauty. sorted.[/SIZE]
question though, what is the difference between euro 1, euro 2 AND EURO 3??:embarasse:embarasse:embarasse
THANKS GUYS :hello::hello::hello:
Euro1 2 3 .. etc is the languages they support .. ALL support English .. but to save space (presumably) they split the rest of the languages supported up into a bunch of different blocks ..
N95 Language Packs
EURO1 - English, French, German, Italian, Spanish, Portuguese
EURO2 - English, French, German, Turkish, Dutch, Italian
EURO3 - English, Czech, Slovakian, German, Polish, Hungarian
Scandinavia - English, Finnish, Swedish, Norwegian, Icelandic, Danish
Baltic - English, German, Estonian, Russian, Latvian, Lithuanian
Russia - English, German, Ukrainian, Russian, Romanian, Bulgarian, Hungarian
Balkans - English, German, Croatian, Slovenian, Serbian, Greek
Arabic - English, Arabic, French, Farsi, Urdu
Hebrew - English, Hebrew, Arabian, Russian, Romanian, Spanish
Africa - English, Portuguese, German, Italian, French
Glad you got it going 😊
i must be doing something really wrong, i can�t get NSS to work, i have uninstalled pc suite and installed the one that came with the phone, and nothing , when i load NSS it does nothing and when i click detect phone it will stay blank for ever, i have also tried to download phoenix , i also get a problem with that, i have vista 32. any help?
BigCol wrote:I want to debrand my nokia N95 8GB but I keep on having a problem. I have installed the drivers from the phone aswell as the nokia pc suite. Nemesis has also been installed. The problem is that when I use the Nemesis and come to scan for phone info, I get a message along the bottom saying "scan for product....error. I am using win xp but I have installed the software and my phone on a leptop with vista home premium and I get the same problem. Can anyone help??????
Try installing a newer version of NSS (NSS103811.exe) with the framework patched dll file. This works for me, even with latest PC Suite installed.
dez_borders wrote:Try installing a newer version of NSS (NSS103811.exe) with the framework patched dll file. This works for me, even with latest PC Suite installed.
I've looked on the NSS site and I am unable to find this version or the patched .dll can you provide a link?
