want to update v20 ,but nokia software updater just fails n95
7 replies · 7,144 views · Started 12 April 2008
hey
i recently just backed up my phone , so now everything is backup
im on a n95-2 and i want to get to version 20 , so i've gone through nss and changed my product code and now im in nokia software update r
i connect my phone via usb to pc suite then start up nokia software updater
it detects my phone at first but i dono why but when its at updating software ,
and like 15 minutes remaining the phone just sudddenly switches off and nokia software update just sais it failed and then the phone just stays on a blank screen i have to restart it then everything is back to normal but it fails and sais like try again but only when the phone automatically switches off
There is a well documented fault in the latest NSU on Nokia's support forums. "Nokia Service Host Layer" crashes and NSU sticks on 15mins remaining - it's a Vista compatibility problem by the looks of things, and Im stuck with it too 😡
fyrestrtr wrote:The firmware for N95-2 is NOT the same as that of the N95. Trying to force it will cause problems.
My friend he's not trying to force anything v20 is out for N95-2 now,its the new 8gb upgrade
millski wrote:There is a well documented fault in the latest NSU on Nokia's support forums. "Nokia Service Host Layer" crashes and NSU sticks on 15mins remaining - it's a Vista compatibility problem by the looks of things, and Im stuck with it too 😡
But there is also a (rather technical) workaround that was originally posted by a_pawsey and has been confirmed by myself here.
argh wrote:But there is also a (rather technical) workaround that was originally posted by a_pawsey and has been confirmed by myself here.
Yeah, I did see that. Looked too complex for me! Glad it worked for you though. I went to my parents house and commandeered the old XP machine which worked just fine...
Hey guys... please some advice - are there any problems with v20 or any MAJOR advantaged or should I just wait for it to come on the euro1 product key? I would really really appreciate some advice.
G
