I sometimes had this before but when i restarted the phone it was back to normal.
Now when I click the menu button the symbol is next to "menu" at the very top of the screen. It shouldnt be there should it. think it is the symbian symbol but it uses up the screen. Hope you know what i am referring to.
I have installed the new firmware twice now and its still there even after restarting phone.
Is yours like this after you have updated your firmware?
how do I sort it?
thats what i mean, thats not right is it.
anyone with the new v20 on their n95 8gb confirm what theirs is like?
Mine is the new euro1 product code.
usually turning your phone on and off will cure that
Ratkat wrote:usually turning your phone on and off will cure that
yeah it used to but it aint now. Ive just done a hard reset and re installed firmware and its same.
Any ideas?
it looks like you not the only 1 with this "problem": http://www.symbian-freak.com/forum/viewtopic.php?t=18170&postdays=0&postorder=asc&start=360
it seems to be permanent...I hope not as I am on the verge of putting the V20 update on my N95 8GB...I also dont't like the old menu style...
this means you have an open apps running to close this press menu button for 2sec then choose the desired app you want to close then hit C button to close this app.
s2kver02 wrote:this means you have an open apps running to close this press menu button for 2sec then choose the desired app you want to close then hit C button to close this app.
no it doesnt mate. Im on about the icon at the top of the screen
are u talking about the icon close to battery meter if so it means your phone is connected thru USB
Im talking about the icon next to "menu" at the top of the screen, the one to the left, the one with green and blue in it. That is not there normally on V15, only once or twice it happened but its there all the time on V20! Its eating up the screen space and its naff
Are the icons smaller then as they are all still shown on the screen?
Cant you see the icon I am referring to?
I had the same thing when I installed Rotateme by Samir.
I find that even if I reboot the phone and the icon has disappeared it will show up again the moment I use camera.
This link may help clarify:-
http://www.allaboutsymbian.com/forum//forum/thread/70608/
did you try changing your theme? coz i think that icon shows only on preinstalled themes i have that on my n82 as well and n95 8gb
[email protected] wrote:I had the same thing when I installed Rotateme by Samir.
This link may help clarify:-http://www.allaboutsymbian.com/forum//forum/thread/70608/
so are you suggesting that it is now correct and the menu symbol should always be there? and not a fault like I thought it was?
s2kver02 wrote:did you try changing your theme? coz i think that icon shows only on preinstalled themes i have that on my n82 as well and n95 8gb
no i like the original theme that I have always had.
Liam548 wrote:so are you suggesting that it is now correct and the menu symbol should always be there? and not a fault like I thought it was?
Correct...... it's not a fault. The icon has always been there. Even on the N80's. It started to disappear when the N95 came out and went into Landscape mode, which does not have the icon.
Liam548 wrote:Im talking about the icon next to "menu" at the top of the screen, the one to the left, the one with green and blue in it. That is not there normally on V15, only once or twice it happened but its there all the time on V20! Its eating up the screen space and its naffAre the icons smaller then as they are all still shown on the screen?
Mine is the same, I always thought this was normal but I don't see how it eats up screen space because if it wasn't there you still wouldnt get any more icons on the screen as far as i could see
baconroll wrote:Mine is the same, I always thought this was normal but I don't see how it eats up screen space because if it wasn't there you still wouldnt get any more icons on the screen as far as i could see
Without the icon the signal and battery bars are smaller, as in landscape mode, and the menu icons appear larger, again as in landscape mode. You do not actually get any more icons on the page, just slightly larger ones.
I'm sorry fellas but this is nit-picking as far as I'm concerned
mobilephil wrote:I'm sorry fellas but this is nit-picking as far as I'm concerned
As the old saying goes, "One man's meat is another man's poison." :laugh:
This question of the missing Menu icon has cropped up before on this, and other, forums over the past 9 month's or so. I know it's not earth shattering but at least we now have an explanation.
It is a fault, the icon shouldn't be displayed in S60 V3 Feature Pack One
You should get the small bar with just the word 'Menu' and the small signal and battery bars.
Another buggy Nokia firmware release.
Previous devices like the N80 didn't use FP1 hence they showed the icon.
Ratkat wrote:It is a fault, the icon shouldn't be displayed in S60 V3 Feature Pack OneYou should get the small bar with just the word 'Menu' and the small signal and battery bars.
cheers. There have been posts suggesting that this is not a fault and in fact it is a fix.
How can we confirm it either way?
