OK, here goes......
I have a n95-1 running v21.0.016 which has decided to go a bit nuts for no apparent reason. If I try to move about using the d pad the display either loses all colour, will turn purple or green, it might freeze, or the screen just dies and goes totally black.
It will come back on maybe 5-10 secs later but this happens every single time. Everything still works, but its more or less unusable. I'm certainly no expert but to me it looked like a software problem. Tried a soft/hard reset, I reinstalled the latest firmware using NSU but to no avail, it doesn't slove it.
Is there any point in sending it off for repair?? Won't they just do what I did and reflash it?
Any thoughts/ideas or what I should say to vodafone customer care would be greatly appreciated.
Cheers.
Sounds like the lcd may of had some pressure pushed against it.
Have you ever removed the casing/changed the casing`?
GSi-R wrote:Sounds like the lcd may of had some pressure pushed against it.Have you ever removed the casing/changed the casing`?
No mate, never. It was in my pocket, during my lunch from work, when I got back to the office it was playing up bigtime.
Puzzled to say the least :con?
kyler wrote:If I try to move about using the d pad the display either loses all colour, will turn purple or green, it might freeze, or the screen just dies and goes totally black.
Hi Kyler, it sounds almost certainly like a hardware problem, exactly as GSi-R suggests.
If you don't want to take the phone apart yourself then it sounds like a trip to the service centre I'm afraid.
Oh well off to get it repaired I go! Thanks for the replies guys
