Watching YouTube videos is a favorite pastime of many. With data charges constantly decreasing (or, should I say, plummeting), not-that-expensive flat 3G data rates getting common, Wi-Fi�s getting pretty ubiquitous and, of course, YouTube�s getting really-really full of videos worth checking out, you might be tempted to watch YouTube (or other) videos on your handset. After all, it's a great pastime and these handhelds have both the processing power, the necessary hardware and, in most cases, connection speed to render these videos well.
In this YouTube Bible, I show you how this all can be done on the three major non-iPhone platforms: Windows Mobile, Symbian S60 and BlackBerry. (As the iPhone, as opposed to most other solutions, already comes with a decent player, there isn�t much point in elaborating on it. You just fire up the YouTube icon and off you go at � if you have Wi-Fi connectivity � very good quality. Nothing needs to be installed and there�re no alternatives you will need to know to make an intelligent decision.)
Note that I�ve published several YouTube-related articles (a quick search for YouTube on my blog reveals these tutorials). These, however, are pretty outdated now � particularly that a lot of vastly superior solutions have been released in the meantime. I�ll, however, refer back to for example the HTC Streaming Media tutorial.
Also note that this Bible is multiplatform, as with the majority of my later Bibles. If you're a fanboy of any of the three reviewed operating system, don't post angry messages like "Why on earth did you include operating system X? I hate it, it's sooooo inferior and lame!". Sorry, both as a gadget-loving geek and as a professional IT advisor / consultant, I MUST know all the mobile operating systems. (Particularly now that the Microsoft folks have just told me they would be interested in some of my week-long lectures on the differences on BlackBerry and Windows Mobile devices. I need such kinds of work because I (more precisely, my employer) prefer getting mobility-related IT consultant contacts as opposed to non-mobility-related ones. This is also why I keep posting on other operating systems - as I need to know them, why wouldn't I post on them? Finally, I won't create a separate version of the Bible for Symbian, BlackBerry and Windows Mobile devices for two reasons: 1. it'd cause me a LOT of additional work not only initially but also when I post a revised, updated version: restructuring the entire Bible, taking out all references to other OS'es; 2. knowing what other operating systems are capable of won't do anyone any harm - you may even find that having read info on another OS useful if you are given a handset running a different OS.)
Also note that, Windows Mobile-wise, the discussion applies to both touchscreen-less MS Smartphones (Windows Mobile 6 Standard) and touchscreen-enabled Pocket PC�s (Windows Mobile 6 Classic / Pro) models. All the reviewed Windows Mobile solutions run on both platforms. In the compatibility lists, I've listed the earliest Windows Mobile operating system a given solution is compatible with but didn't list them all. This means if you see WM2003+, it means compatibility with WM2003 and all subsequent operating system versions (WM2003SE, WM5, WM6, WM6.1), not only with WM2003.
1.1 Browsing the desktop Web version of YouTube
This section applies to both platforms of Windows Mobile starting with WM2003+ and used with Internet Explorer Mobile (IEM) and Opera Mobile; Symbian with integrated Flash Lite 3.
1.1.1 Windows Mobile
1.1.1.1 IEM / Opera Mobile + Flash 7 plug-in
If you install the Flash 7 plug-in (see the Flash Bible HERE for more info on the availability etc.) on your Pocket PC and either use the WM5+ (not earlier: due to bad JavaScript support, they won�t work) Internet Explorer Mobile (IEM) or WM2003+ Opera Mobile (any version), the videos will be played back in-line, just like on the desktop.
This is, however, the worst approach you should ALWAYS avoid because it, in some cases, grinds the entire handset to halt and is very slow, even on high-end Windows Mobile devices. All in all, it�s in NO WAY recommended - there are far superior approaches.
1.1.1.2 IEM + FlashVideoBundle
This is an immensely better solution having all the advantages of the desktop version; most importantly, direct access to YouTube, Google Video & Veoh links sent in, for example, mails. Then, when IEM is invoked, you�re shown a context menu, where you can instruct IEM to show the video in TCPMP, save it into a file or, alternatively, take you right to the page so that you can see for example the comments / related videos:
If you directly enter the URL in the address bar (by, for example, pasting it to there), it�ll too present you with the same context menu; the same will happen if you just click a video link on YouTube (GV etc.) pages.
The current version is 1.4.4; CAB file available for download HERE (if you don�t want to register, I�ve mirrored it HERE); my old, now-outdated article HERE. Installing it is pretty straightforward; just follow the section "Installation instructions" in the tutorial on the homepage.
This is one of the most recommended ways of playing back online videos, particularly if you get links in e-mails / other, offline documents like Word files.
1.1.2 Symbian with Flash Lite 3
In order to play back (Flash, including YouTube) videos embedded in Web pages, you�ll need to have a device with Flash Lite 3 preinstalled. One of them, the, currently, best multimedia handset of all, the Nokia N95 received Flash Lite 3 support in firmware version v21 released some weeks ago.
If you have a compatible handset, you don�t need to install anything else (no third-party apps at all): videos will be played back right in the pages that contain them, with much-much less adverse effects than (currently) with Windows Mobile relying on the CPU-hog Flash 7.
As has already been emphasized, Flash Lite 3 on Symbian behaves much-much better than the full Flash 7 on Windows Mobile. While the latter is in no way recommended, the former � if you have a Symbian device � is. Note that you can still use the Mobile YouTube Web and the MIDlet-based interface too (see sections 1.2 and 1.3, respectively), but they only deliver 3GP videos at a much lower quality than Flash Lite 3. Alternatively, if you need high-quality (Flash / H.264) videos, you may also want to prefer Mobitubia � or the soon-to-be-released, YouTube-capable version of CorePlayer.
Note that Portrait playback will always be oversized as can be seen in THIS screenshot (source link HERE). Also, if you use the standard Nokia Web menu (Options / Rotate Screen) to switch to Landscape mode, it�ll stay oversized. The trick is clicking the Flash Lite 3 surface with the Action button � it�s then that it�ll be resized to fit into the screen as can be seen in the first screenshot.
Also note that there�s still no Flash Lite 3 on Windows Mobile but will, hopefully, be soon released; see THIS and THIS for more info.
