Hi everyone,
I have thousands of text messages that I need to keep. At the minute, i cant upgrade my phone until i find a way of 'porting' the messages from the e50 to the e65.
Does anyone know if this is possible?
I'd be so appreciative of any help - my e50 really is on it's last legs!
Dermot
Have you tried with PC Suite via Phone Browser? You can access your sms and contacts...
The fastest way to transfer data from a nokia device to a S60 device is with the built in transfer app. In my phone it's located in tools -> utilities and it's called transfer but my language is Spanish so perhaps it's called diferent in english. When you load it it's called data transfer and here you can sync 2 devices or transfer data from one to another the way you want (send or receive). And as I said you don't need anymore, just run this, select the device you want with bluetooth active on both and the program will send the needed tool to the other phone (a S40 o S60 phone) and then you only need to select the way of sync and what data you want to transfer (you can select almost all, even the call log).
