nokia maps 2.0 doesn't allow route planning
4 replies · 2,424 views · Started 04 May 2008
have nokia maps 2.0 Beta installed, in the begining the planning of routes functioned well. Now when i try to plan a route, i get the screen of accept terms and conditions, then the screen of try & buy the walking route download. If i click no, the whole route planning cancels, if i click yes i am presented with a screen with a list of prices.
Any ideas?
Thanks in advance
thanks, constructive.
As i understoo with nokia maps, you only need to subscribe if you wanted voice directions, as i don't, why subscribe.
Thanks for your advice
It does work - though not as intuitively as it might.
You have to "find place" (or "use this place"😉 then you get new menu options.
"route from" and "route to" give you the route planning (without voice prompt) and "navigate to" gives you guidance if subscribed (or asks you to subscribe if you're not)
HTH
